Hi everyone. I have a pool pilot nano generator that was supposedly put in a year ago. I am getting a check flow error. I have done everything the manual and what online research recommends and still get the error. All chemicals are at the required/recommended levels including the salt(3200 ppm). Made contact with the manufacturer who said to check continuity of the cables. When I run a test in the menu I get a different reading of the salt level(3000). It also reads 0 volts and .2 amps. The only fuse I see is fine. This leads me to believe the power supply is shot. Does anyone have any ideas as what to check now? Would I do a continuity check on both the flow sensor and the cell and is there a way to check the power supply itself
