I have a hayward tristar vsp and a hayward aqua rite salt chlorinator. Im using the built in tkmer on the pump to time the pump. The salt chlorinator is not on its own timer.
1. Can I wire the salt chlorinator directly to the pump so it can use the same timing sxhedule?
2. If not, do I need a separate external timer to hook the pump and salt aystem to so they are on the same schedule.
My salt system is constantly running even when my pump is off causing issues to my salt reading and chlorine creation.
