What is the Ohm resistance supposed to be on a new salt water cell between the common and outer ports? A Jandy AquaPure R0452400 PLC1400 3-Port Cell was burning center port and melting connector. Disconnected and dry, the resistance from center to outer is about 7kOhms (10kOhms between outers). The reading increases the longer the probes are held. Is that typical? I wonder if the cell is good and a new cable would fix it. A dead one measures open circuit between all ports dry.
