My S300i called it quits... going out in a similar fashion to other posters in that it fails the startup tests after moving a few seconds forward and a few seconds backward. It does start on it's back and out of the water, but the gears clackety clack loudly and are slipping. Without going much further I assume it's one of the two motors, or both plus well worn gears/hubs/rubber. I dissected the machine and opened the impeller motor, finding caked up carbon dust on the armature and almost zero wear life left in the carbon brushes. My unit is 4.5 years old. As others have noted before me, it will cost $300-$600 to rebuild the unit and try to get a couple more years life from it. So I'm looking into buying a replacement.
I have the opportunity to pick up a Dolphin S200 for about $800. Since it's similar to the S300i I would plan to use my existing caddy and my extra/various basket filters so that's all a plus. Am I crazy? I'll be averaging about $200/year for the privilege of having a robot. Does anyone know if the S200 robot itself is "exactly" the same as the S300? I wonder if I could plug the S200 into my existing S300i power supply and have the S300i cleaning cycle features?
I'm also open to recommendations. I'd love to find a lower cost unit that lasts at least 4-5 years and does as good a job cleaning as the S300 did. Our pool has a heavy leaf and "crepe myrtle trash" load each year so a large capacity basket is a huge plus. We tend to leave it in the water (not a great practice, I know) and run it 6-8 times per week during the season. I see the many new, lower cost brands on Amazon but I'm yet to find any with a solid enough history to make me comfortable rolling the dice. Thoughts from anyone who's having a great experience with the new lower cost units is appreciated - especially if you're a couple of years in with good reliability/performance.
Thanks!
Thanks!
