SeanThePoolFreshman
79
Hanover, VA
Hey everyone,
It's been a while since I have posted, but I had a bit of a mishap that actually works a bit in my favor. Opened up the pool for cycling and filtration about a week too early and ended up that we had a hard freeze and I blew a pipe. Consequently, I also lost 2/3 of my water in the pool. This is a blessing in disguise as it allows me to see that the haze and cloudiness issues I was experiencing last year is due to paint that has been scaling and separating from the surface of the gunite. I have been looking into a product called Rebound, which can be found here: Rebound Pools but it will be about 2 years before I can make the investment to surface the entire pool surface in it. In the meantime I need to get a paint that is non-water permeable, safe for gunite, safe for swimming and that is affordable. I just need to have it hold up strong for 2-3 years while I save for the Rebound surfacing. I will be doing the work myself, so something I can get at a local hardware store or order easily online would be great. The surface area is roughly 1,500 sq ft that I will need to cover. I am going do a light sand blast to the inside of the pool and then will surface sand the remaining existing paint. After that I plan on acid washing the walls and bowl of the pool as there is some previous algae buildup on the surface where the paint has peeled away. At this point of work completion though I am unsure of the product to use to ensure that I do not have any leaks into the gunite surface and that will be enjoyable to swim in for the next few years. Any feedback or suggestions would be greatly appreciated!
Thanks, I will be posting pictures along the way so everyone can see the improvements from the feedback.
There is no pool paint product that we recommend. They all chalk and don't adhere soon after application.
Pool paint formulas that worked many years ago have been outlawed by EPA regulations. Pool paints you can buy today do not work well.
Reactions: SeanThePoolFreshman
For easy reference these are the pools steps:
Is there any product that you would recommend? I know about pebbletech, glass etc, but I just need to get the pool operational for a couple seasons until I can afford to install the Rebound pool surface product.
I would just live with what you have until you can resurface the pool.
Hey there...good to see ya again :)
I only found ONE post that referenced REBOUND finish, and it was a question about it. Not a review. We just don't know anything about it and if it were common we surely would have heard more here at TFP.
We have heard that painting pools nowadays is *nothing* like in decades past. The paints now just are different and don't hold up more than a couple of years, if that.
Maddie :flower:
Maddie :flower:
Great to be back. The rebound product is the same that is used in splash pads and such around the country but is relatively new for private pool usage. Currently not looking to get the pool done with the Rebound product, but I need something to put as a finish over the exposed gunite in the pool as the old paint (best of my knowledge has been there for almost a decade) is completing coming off. Not necessarily paint being the way to go, was just a first thought option. Primarily looking for surfacing solutions and recommendations so that I know the pool will not be damaged and the kiddos can have a fun swim season.
Here is a thread on my painting project.... Pool repair and painting
and a thread from household6.... www.troublefreepool.com/threads/its-pool-repair-weekend.91691/
We used Insl-X Semi-Gloss Swimming Pool Paint ( water-based acrylic ). I believe it is made by Benjamin Moore, and we found pricing from $49 a gallon up to $70 a gallon.
Home Depot had the best cost so we ordered from there.
I think water based acrylic is the only paint that can be used over any type of existing paint.
Paint may not be the best option but in our cases(s) it has done/exceeded what we were hoping for
If you have a slow leak in your pool, that would have to be address first as a paint job would not seal a leak
...and you've checked around the skimmer (common) or lights?
Pressure tested lines, dye tested around lights/main drain/vacuum port/both skimmers, checked seals and valves in pump house as well. I am replacing a light right now that was never even in the pool when we bought the house. The nitch was puttied thoroughly though and no leak was present.
Ok, so this addresses my thoughts about the painting. Thank you!
Well, just wanted to give some updates. I forgot to take pictures of the new plaster, but got most of it in there. For a 1 person job I think it turned out well. An epoxy resin paint, 4 coats. Water is back in the pool and seems to be holding. Replaced both lights, 1 was missing since move-in amd the other had frayed wiring (super super dangerous and didn't know), replaced both skimmers and 1 return pipe. New eyelettes for all 3 returns.
Thank you all for the support and advice. Total savings is roughly $35,000 from what I was quoted for a commercial company to do. They wanted $42,500 for the lowest quote and all of the work listed above.
