Rusting elements and stain. How do I fix it?
Pokot0
3
San diego
Hi, I have a SunDance Cameo hot tub and recently some parts rusted and stained the fiberglass (probably too much chlorine, don't ask! I was out of town for more than a month and messed up).
Anyway, picture attached:
- Are the stains removable somehow? They don't seen to go away with soap and water.
- Are the rusty elements available for purchase? Do they have a name? Can anyone recommend a parts shop?
Thank you!
The handle is called a grip bar. The plastic piece to seal the grip bar is called a rubber collar. The light is a light assembly.
Contact SunDance with your model # and they can provide you part numbers. 1-844-602-6065
You can remove the stains with Vitamin C tablets. Rub them directly on, or put in a sock, crush them, get them wet and rub on the stains directly.
Looks like hot tub outpost.com carries some sundance cameo parts - just type in what you’re looking for in the search bar.
Reactions: Pokot0
