Running pump hours
cm35
120
Hillsboro Tx
I know that during a slam you have to run your pump on high, if you have a 2 speed, but what about any other time?
Shutoff at night?
Run on low except when adding chems?
Run on low all the time?
I’m in Texas and it’s 🥵
You shouldn't have to run your pump on high speed during a slam. As long as your water is circulating you're fine. You do want to keep it running 24/7 during a slam. Make sure you clean or backwasher filter when pressure increases 25% over clean pressure.
Besides a slam, is it cool to let timer turn off pump from say….sundown to sunup ? Just run during daylight hours in Texas?
Yep. No problem with that if it works for your pool.
Reactions: cm35
