Hey Guys! I’m fairly new to this forum! Been reading and learning a lot! We finally got our pool looking GORGEOUS by using the SLAM method on this site! Thank you for that! We are starting to have more accurate chlorine and CYA levels again. We have a vinyl in-ground pool 17,000 gallons with a chlorinator and a pump that we currently run 24/7 because I’m scared to mess the pretty water up again! We are looking to reduce our pump run time. We live in Middle TN. It is pretty hot here lately with very minimal rain. We do have 4 large trees around our pool that causes quite a bit of leaves in our pool.
So we are curious how often per day we should run our pump to keep it clean and well chlorinated. We do not have a pump timer so it would be best if we could run it for the amount of hours at one time as opposed to intermittently. Also, what time of the day is best to run the pump?
Thank you for your time!
