My pool is new and just had the swg installed and I am taking care of it myself. The pool is about 12,000 gallons, has 3 18” waterfalls which I run all the time (10hrs/ day) and the swg is a Chlorsync cs30 which I have set at 35%. My stats are 5ppm chlorine, 90 TA, 40 cya, 300 calcium hardness and a runaway ph. I get it to 7.4-7.6 and in 48 hours it’s back to 8.2. I’m using sodium bisulfate to lower the PH.
Is this normal? Am I releasing too much co2 through the waterfalls? Should I run the pump less?
