Hi,
Recently my Intelliflow Pump died, decided to change to a different brand pump not compatible with easytouch.
now when the pump is running (independent of EasyTouch), i want to activate the ic40, so I am running the easyTouch on the same schedule as before.
what i see is that ic40 comes on for 1 sec (when water is flowing) and shuts off, cant even read which lights come on. Cannot tell if ic40 has also died or is it not running as EasyToch doesnt detect pump running.
question is do i need to change any settings so ic40 can run without easyTouch?
I know this makes easy touch a very expensive automation piece that will only control ic40 at best
