- Dec 13, 2020
- 751
- Plaster
- Jandy Aquapure 1400
Hello all! Really appreciate the amazing kindness and skill found here. Thanks for past help.
We are changing our RS Aqualink system from a single speed Whisperflo to Intelliflo VS pump. I'm trying to figure out how this will work with the Aquapure SWG, also controlled by the RS Aqualink panel.
What I think I know:
But of course.... "It's what you don't know that you don't know that will kill you." Any advice will be appreciated.
- The pump 220vac and the Aquapure are both currently switched by the pump relay.
- The VS pump wiring needs to be changed to not switched.
- The pump's RS-485 needs to be connected.
- The SWG has a 40 gpm min flow rate. (Just installed a flow meter to help VS setup and it's showing 105gpm. Yikes!)
- It's not a good idea to rely on the SWG's flow sensor for daily control.
- Do I leave the SWG connected through the relay? I suppose yes, but not sure.
- For a pump schedule that includes times with < 40 gpm, how does the SWG get turned off in that period?
