As per the pool math calculator, I added 3.5 gallons of liquid chlorine to the water. However, I was only able to wait 10 minutes before taking a sample to the pool store. Considering the results I got from them I decided to use a test strip as well.
Pool Store
TH - 70
FC - 0
CC - 0
pH - 7.6
TA - 60
CYA - 0
Test Strip (sample taken 30 - 40 mins after adding LC) Also, the test strip does not measure CC.
TH - 100
FC - 5
pH - 7.6
TA - 40
CYA - 0
Lastly, in the spirit of full disclosure. The water is slightly greener this afternoon than it was last night. Should I wait to re-test tomorrow before adding more LC?
@yippyskippy, I thought about converting to a salt system and decided to stick with my current setup after the warranty company agreed to replace a bunch of stuff that was not working properly.
