Now tell me what some of those parts are. The only one I know is the screw driver LOL. I love learning new things and this is ALL new to me!
Kim
Kim
I"m following along with Kim!
Maddie![]()
Red board-I get why it is named that hehe but the "bread board" ??? Why bread board? as in why did they name it that?
Here at TFP we are not super strict about keeping every thread strictly pool related. This is your thread so you are free (and encouraged) to share all of your fun with this new toy!
Salsiccia, I am rooting for this project...my plan is to have the temperature transmitted to my spreadsheet as well, but my temperature sensor is in the pipes rather than floating in the pool. I am sure you realize the advantage to your method...you don’t have to have the pump going to get an accurate pool temp reading. Like you, I want to get accurate readings throughout the day for my data collection (I don’t know yet what I’ll do with it all, but I want it, haha). But I don’t like to run my pump in the middle of the day during summer (peak electricity rates), so haven’t decided how best to solve this.
Search around for pool temp monitors (instead of pool controllers as my previous suggestion). There are quite a few of those as well...water proofness and battery life are two of the issues that people run into with a “floating” temp monitor.
pH readings are In my future, too...so please get it working, haha. Lots of DIY projects have been been posted on the web...but there is usually little follow-up to indicate whether or not the project’s original goals were accomplished.
Sal,
I'm following with great interest. I just started playing with EXP 32 control and seem to have figured out how to interface with wifi very easily using canned software that just needs minor modifications. My goal is to wifi contol swg and other equipment. I currently use iAqualink automation and I love it but this sort of locks me in to their equipment. Also Jandy is now eliminating all warranty for DIY installation of everything except valves and valve parts. So I'm a "motivated developer".
Good luck to you and I'll follow with great interest.
Chris
Sal.
I couldn't agree more. I'm not really anti the great manufacturers I really am thankful they compete so much to one up each other with better and better equipment. I just wish there was a standard protocol for control instead of each manufacturer using slightly different protocols to make it hard to switch. Seems like a universal protocol for pool control is much needed but none of the manufacturers are incentivized to do this nor adopt it.
I'm taking a slightly different approach because eventually I want to have full control via wifi. I'm starting with a couple of projects in sequence that I hope will get me there. First, I just want to open and close a valve and valve position indicated on a phone via wifi. Then I will try to fully automate my Circupool SWG. After that I think I'll be able to replace the board of my iAqalink with the esp 32 and use any equipment I want with anything else. I've think I've figured out the first step on the esp 32 and just need to finish the bread board and test it. A disadvantage I have is that I'm not an IT type so learning to code is challenging. I learned Basic and FORTRAN 40 years ago so that helps a little, but not much. Right now I'm also playing with opto couplers to emulate button presses which is turning out to be pretty easy, but I'm still trying to find the best way to get display back to my app from the device. There's a great You Tube video here that explains the opto coupler on the esp8266 (one generation earlier of the esp32). I'll post as I make progress.
Chris
All routed through a smart things hub. If all you want is a temperature sensor, even the normal motion sensor for smart things has temp readings in it. Water proof it easy enough and bingo.
Sal, the Photon is an arduino-like component that is supported with firmware/cloud functions that make it easy to interface with it, at least for someone who knows what they are doing like my son-in-law. The photon is probably overkill for a floating temp sensor but there are some using it for that purpose.
I am going with your thoughts as it does kind of look like a piece of white bread!
