- May 18, 2023
- 96
- Plaster
- CircuPool RJ-45 Plus
Finally got the RJ45+ installed and said goodbye to jugs. A little messy but we’re done. I’m trying to get it dialed in now and have a few questions.
1. Set at 50%. I have a Tristar VS950. I’m trying to figure out what rpm to run the pump at. When I try lower rpm (1200-1500) the no flow light flickers and then after a minute or so the generate light kicks on. Is this normal? My whole point of purchasing this was to run at an rpm as low as possible to maximize electricity savings with 24/7 pump run time. At 1600 rpm it kicks right on but I don’t really want to run that high if it can be avoided.
2. There seems to be a small bubble in the cell. Is this anything to worry about? Tried my best to get a photo.
3. If I can get the SWG to generate at a lower rpm I plan to run 24/7 so I didn’t install an intermatic timer but it’s wired to the same breaker as the pump - is this an absolute no go to not have a timer if pump runs constantly?
