Our pool water is sparkling, no problems.
I am trying to better understand the source of my pool's daily rising pH and slightly creeping up TA. Pool is plaster with embedded small pebbles. It is one year old. The current pool chemistry is:
CL 6.5
CC 0
PH 7.8
TA 80 (acid drops the TA but then it creeps up 10 ppm over the following week)
CH 450 (up from 400 three weeks ago)
CYA 70-80 (stable)
Salt 3650 (stable)
Borate 48 (manitol tested)
Temperature 84
In the past 6 days, I've added no water and we've had no rain. I have physically unplugged the Salt cell. Pump runs at 2000 rpm, all water features off, there is just the slightest movement on the surface. There are no bubbles entering the pool at the returns. I have been dosing the pool daily with 16 ounces of 15% chlorine bleach as the 17,250 gallon pool uses about 1-1.5 ppm chlorine per day.
Two days ago the pH tested 7.6, yesterday the pH tested 7.7 and tonight it tested 7.8. My understanding is that CO2 outgassing is the primary culprit in pH rise. With the situation as I've summarized it, does my pH rise sound like CO2 outgassing or something else and if so what would that be? Thanks in advance for any ideas.
Naples Water (shut off for the last 4 days, evaporation less than an inch)
pH 9.25
CL 0.4
CC 3.2
TA 30
CH 50
CL 6.5
CC 0
PH 7.8
CYA 70-80 (stable)
Salt 3650 (stable)
Temperature 84
pH 9.25
CL 0.4
CC 3.2
TA 30
CH 50
