I recently bought a house with a small in ground pool with a Rheem M6350 heat pump. The contactor went bad causing the compressor to not be able to turn off. I had a local HVAC company fix that and it worked fine for a few weeks. Now, when the compressor tries to turn on, it makes a weird noise, shuts off, and the compressor delay light comes on. This repeats until I turn the heater off. The guy they sent out this time doesn't seem to know a lot about these. He thinks the internal water bypass has failed causing a lack of water flow over the heat exchanger. This is what is causing the compressor to turn itself off. He checked the high and low side pressures and said the high pressure spikes up to about 590 when it cuts itself off. Does this sound like a water flow issue or something else? Anybody have a suggestion for a company in Panama City Beach that works on these?
