- May 23, 2015
- 25,703
- Plaster
- Pentair Intellichlor IC-60
When reducing TA, it’s easiest to just use PoolMath to calculate how much acid to use to lower the TA by 10ppm. When the TA is high, taking 10ppm off will create very small differences in pH. As the TA gets closer to 80-100ppm range, dropping 10ppm will have a much more noticeable impact on pH. Just simply wait until your pH rises above 7.6, then hit the TA again. Acid addition will go quickly at first and then really slow down once you get below 100ppm TA.
