I am about to be a pool owner. We start digging next week. I was hoping some of you pool gurus on the site might be willing to review the equiptment that the contractor is putting in. Essentially I just want to get another set of eyes on the equiptment plan to see if anythings stands out, such as an oversized pump that's going to cost me $$$$ to run. I really have no expertise so I am all ears.
POOL: Freeform shape, 28’ x 13’, 7’ x 10’ tanning shelf, 90’ perimeter, 3 ½’ x 6’ depth. Constructed of 4,000 psi shotcrete with #3 steel rebar tied 12” on center, minimum floor and wall thickness 6”, minimum bond beam thickness 12” with #4 steel rebar.
PLUMBING & EQUIPMENT: - BASE PRICE: $14,400.00 – less $5,500 for heater/gas line
All 2” PVC schedule 40 with Jandy never lube valves.
(2) Hayward skimmer with equalizer
(2) Return inlets
(1) Pool overflow fitting
(1) Pool cleaner line
(2) Anti-vortex pool and spa main drains with covers that comply with federal VGB mandate addressing anti-entrapment requirements.
(2) Multi-Color LED pool light
(1) Pentair 2hp WhisperFlo Filter Pump
(1) Pentair Clean and Clear 420 sq. ft. cartridge filter with pressure gauge
(1) Pentair IntelliTouch 4 Automation system with programmable event timers and freeze guard protection with remote control.
(1) 399K BTU Pentair MasterTemp Heater – Gas line included
(1) Pentair IntelliChlor IC40 electrronic chlorine generator up to 40,000 gallons, (salt Included)
(1) Polaris 280 automatic pool cleaner with dedicated booster pump
(2) Return inlets
