Quick backstory: Been in the house almost two years now. Started with pool service but they were so unreliable that I decided to try to do it myself this season. Getting comfortable with the chemistry, but been battling clogged lines recently.
My setup has two skimmers at each end plus a cleaner port in the middle. The cleaner port has never had great suction, so I've been running the cleaner off the skimmer closest to the pump since it had the strongest suction. A couple days ago I noticed that the cleaner was moving slowly, so I checked the suction and it was much lower than normal. Tried opening and closing the valve and using a snake on the pool side but so far nothing has helped. I've tried to snake and water jet the cleaner port line before and it didn't help either. Pump pressure is currently at 15psi. with the one good skimmer fully open and the drain open halfway.
Any suggestions on how to get the skimmer and cleaner port lines opened up? Or am I missing something else that might be causing the lack of suction?
