- Feb 6, 2015
- 7,819
- Plaster
- CircuPool RJ-45 Plus
You can always drain the spa first, attempt the drain cover fix and then fill the spa with fresh water. This would be one less thing to water down. Dump a cup or two of bleach in the spa as your refilling or after refilling and mix with the brush.
Try to refill the pool using multiple hoses - it will go faster.
