Thanks. Do you recommend that it be pointed in a way that it barely causes ripples on the surface?
A little surface movement is great if it helps everything go to the skimmer or close to it. As long as the rippling isn't so strong that it's causing the pH to rise (via aeration) it's fine.Do you recommend that it be pointed in a way that it barely causes ripples on the surface?
That's a great idea!You can also grab some ping pong balls or packing peanuts, toss them on the water, and monitor their movement to adjust the return jet angles for optimal performance.
