- May 18, 2021
- 63
- Vinyl
- Jandy Aquapure 1400
Just starting prep for liner install tomorrow on my semi inground steel wall. Getting conflicting advice on when to install the return fitting. Picture is attached and the only gasket is between the faceplate and the fitting. I assumed for that reason the fitting would be put in place before the liner and then cut out just the center portion when water just below return. Faceplate then installed. A friend putting up same pool says to push fitting into return hole after liner is installed and cut from back side. I've seen that done lots but with only the one gasket I think that is incorrect as there would only be a seal between faceplate and return and not return and liner.
Thanks for your thoughts
