Hello and Welcome to TFP!!
Here is a
link to edit your siggy . You can use some of the posts in this thread as examples of what to include. Pool size, volume, wall type, equipment type & model numbers if you can get them. Anything you can provide will help.
Lets not overwhelm you. How about starting with providing some general info. Is your pool filled with water or is it empty? After 8 years, we can safely assume you will need to get the equipment prepared and make sure it works properly. If you take some pictures and post them in this thread, we can help you figure out what you have. There are a lot of helpful members here that can help you figure this out.
You will need a good test kit to clean the water properly. I highly recommend the TF-100 with XL option from
TFTestkits.net. This will allow you to test the water and give us the details we need. Don't worry testing the water is not difficult. After a couple of tests, it becomes easy.
I agree that it would be a good idea to have a service company come out and look things over. That is unless you feel that you can do this part yourself. There is bound to be something that needs some work.
We will do the water cleaning with liquid chlorine (aka bleach). Start looking / calling around to see what is available in your area. Walmart pool section typically has the chlorine at a good price.
There is a lot of things to consider and we can help you figure it out. Keep all your information and questions in this thread so that we can have it all in one place.
If you want to start with some reading, You can visit our Pool School articles. Start with the links below.
Opening a closed pool
Pics/names of typical pool equipment
ABC's of pool water chemistry
How to chlorinate your pool
SLAM process
