Alright... second battery of tests performed. See first post for results ran on the straight fill water. This is results from today after about a week in service.
FC (using the FAS-DPD test): 6.5
CC: 0.5
pH: 6.8
TA: 160
CH: 420
CYA: 30
Water clarity: pretty much crystal clear. Temp: 74F.
I took these tests about a two hours after I added the day's chemicals, which included a heaping amount of bleach and MA as usual. My target was 5ppm for chlorine and 7.2 for pH. Not sure if my pool size estimation is incorrect or what but if the pool behaves anything like it has every day for the past week, it'll be back up at 7.5-7.8 by this time tomorrow.
TA seems a bit happier at 160... a loss of 40 due to the ~180oz of MA I've added over the last week. It's spot on with the 'if you do x, then y happens' part of the Pool Calculator. Still quite high, and it's still jacking up my pH constantly, hopefully it'll even out in a few weeks if I keep on feeding it MA.
CH... wow... seems to have increased. I did this test for the first time using the Speed Stir so I'm pretty sure it's accurate. The first time I did it today I thought the color turned purple, so I looked at the fading endpoint notes and re-did the test, adding the 5 drops of the titrant first before the other chemicals. I guess it could still be a bit off and I can re-perform it again and even record it if you guys think I should. Is the high CH a concern? The recommended levels says it should be between 0-350.
CYA... I added enough stabilizer last week to get it up to 40. But as you guys know I've been cleaning my filter like a maniac since filling the pool, so maybe part of it got cleaned out... although I did add it in via the sock method. Should I wait a few days and re-test, or go ahead and add enough stabilizer to bring it up?
CC: 0.5
pH: 6.8
TA: 160
CH: 420
CYA: 30
