Moved into a home with an existing system. No OneTouch, PDA or other control so I'm looking to use the web or phone app. Spending the last two weeks troubleshooting and reading over multiple posts. Now looking for other troubleshooting ideas. I don't mind going outside and pressing the buttons in service mode but would like to monitor from inside if possible and use a schedule.
Jandy RS 8 REV R board
iQ20-iAqualink2.0
What I have tried so far
-checked connection from iQ20 to RS485
-checked all RS485 4 pin wired connections - all snug no loose wires, all in the correct pins
-checked pin seatings of all RS485 to include the 6585 multiplex board (all 4 being used on board)
Each test I would
>remove "pool" from the app or website
>toggle the switch from wired/wifi in iAqualink to clear settings
Tests
>>able to add "pool" using home network (smart network either 5G or 2.4)
>>able to add "pool" using guest network to force 2.4Hz network
>>able to add "pool" using a direct wired connection (CAT5) into a router
Results - All three had the same result. I've tried each method multiple times.
>From App - Red Circle - Connection Error
>From Web - It says Online but hangs on blue screen "waiting for connection"
Any other troubleshoot thoughts?
iQ20-iAqualink2.0
Each test I would
Tests
