My 2-year old Whisperflo motor is shot. Found the breaker tripped. When I reset it there was an arc from the windings (I discovered later, evidenced by observed soot), toward the back underneath the connection terminals. Breaker tripped again. Tightened up the connections. Reset the breaker. Humming only. Changed the capacitor. No change. Impeller is freely spinning by hand. So, new motor, right?
So, the question:
I was researching a replacement motor and had a thought about replacing with a 2-speed motor. I had originally considered a completely new VS, but I see a lot of complaints about the electronics frying. Don't want to mess with that for the cost.
I searched and found where someone else did the same thing I am now considering...upgrading from a single speed to a dual speed, but the post is 3 years old and wanted to see if I can get any other updated advice.
The dead pump is for the filter and the spa-jets when in spa mode. I have a separate pump for a water feature plus a booster pump for the cleaner.
Here are the specs of the current and straight replacement motor I believe POOL360 - 2HP 208-230V 56Y THRD SQFL EE ODP MOTOR
The replacement motor would be POOL360 - 2HP 2SP 230V 56Y THRD SQFL EE ODP MOTOR, I assume.
Reviewing the wiring instructions I can find for the EasyTouch controller, it's my understanding I'll need to add the two-speed relay to my control box and run an extra cable from the control box to the pump itself.
If you can all help guide me with respect to the following I would be very appreciative:
1. Is replacing the single-speed motor with the dual-speed motor the right way to go?
2. Have I identified the correct dual-speed motor for my pump?
3. Can anyone share a wiring diagram?
Lastly, assuming I get the dual-speed pump wired up correctly, can someone help me with the programming I'll need to do on the EasyTouch to take advantage of it? I basically want to run it on low speed for general filter use and on high speed for spa operations.
Thanks in advance for your help!
Jeff
So, the question:
Jeff
