My pool pump burned up & needs to be replaced; I currently have an an AquaTools 1.5 SPL pump (single speed - P/N AT2515000; Manufactured in May 2011). I have a SWG controlled by Pool Pilot, which also controls the pump in some fashion - there is an adjacent timer, but I don't think it is used.
I can't find any information on AquaTools; Not sure how to start picking out a new Pump. My power Company has a $500 rebate for variable speed pumps, so I want to look into those. My Electric bill is significantly higher during pool/Spa season ( $80-120/month).
Pool pump only runs the pool; As mentioned, I have a Pool Pilot SWG, Pentair heat pump, single skimmer, bottom drain, and 2 returns. No water features; 23K gallon pool, roughly kidney shaped.
I would like to install myself, as tearing apart the current one was pretty easy. I would like to get a similar size pump, to avoid doing plumbing work. So:
1.) How do I select the new VS pump - the same 1.5 HP? Are there other considerations?
2.) I assume I will need to do some reprogramming of the pool pilot to account for the new VS pump; Are there any threads that discuss this?
3.) Any brands to recommend? I have heard pentair is a decent brand, but not much else. Quality/duration, ease of maintenance and Installation, and efficiency are more of a concern than upfront cost.
Thanks in advance for any assistance!
