So I opened my pool on Friday and it looks like this (considering replacing my mesh to solid cover)
Also my pool motor was humming and i tried to get the shaft spinning....found this:
Tough winter in NJ. Needless to say my attempts to get the motor started was halted after I broke off a few corroded screws trying access the shaft.
Now after 6 years I manage to figure out what the previous owner did.\
Pool must have been built with a 1.5 HP Dual speed motor (found the extra wire) and there is a 1.5HP impeller and housing (see pic) Also he replaced the 1.5HP Hayward super pump with the 2.0HP motor.
I ordered the Hayward 2.0 HP from amazon and it will be delivered tomorrow. I am not sure what to do. Should I send it back and get a legit 1.5HP motor? I only figured this all out after realizing my strainer basket/housing ports are 1.5 inch. and the 2.0HP Hayward pump comes with 2 inch ports. Any suggestions?
I haven't had any issues the past few years but I'm sure running a 2.0 HP motor coupled with a 1.5hp impeller may not be ideal.... please advise:
Thanks in advance all...
Ravi
- keep 2.0HP single speed and 2.0 impeller. redo pluming to use 2inch ports.
- Keep 2.0 single speed HP motor and use old 1.5 HP impeller/housing
- Return the 2.0HP single speed and get a dual speed 1.5 HP
Ravi
