We have a fairly gigantic (20' x 40') gunite pool that has been around for nearly 60 years. The previous owner was 93 years old by the time we bought the house, and all of the neighbors say that the pool went a good 8-9 years without being opened. I was able to get it sparkling clear last year and enjoy it for about half the season, thanks to the abundance of knowledge on this site -- so thank you all for that!
Now, there is a ring of tile around the top 6 inches of the pool, and through age and neglect it has fallen into complete disrepair, to the point that many of the tiles have actually fallen off and shattered on the bottom of the pool. Obviously, this needs to be replaced, and my wife and I would like to do this ourselves.
My first question -- and I'm sure more will follow -- is this: do I need to use an angle grinder (or some other tool) to totally level out the surface in preparation for new tile? Or, will I just level out the surface with mortar? I'm guessing the former, since it seems the tile will otherwise not end up looking flat and even in the long run if I try to take a shortcut. I can get some pictures later today if necessary, but it looks very rough where the tile has fallen away, and I'm guessing that is likely the case behind all the tile.
If an angle grinder or some other tool is necessary, does anyone have a specific recommendation that has worked well in your experience?
Thank you in advance for your help!
