Hi
This is my first posting. I am replacing the return lines in my IG pool. Old lines were fully compromised. Cut concrete and replaced 1 return successfully using Flex 1 1/" PVC with no issues. The problem I am having is getting the old one out through the liner. I did succeed with a little stretching. I am now trying alternate ways of placed the new one OVER the liner and through the wall. It leaks on opposite wall. Its a small leak (droplets) but enough to force me to try alternate methods to suppress leak. Do I have to pull the liner over the return?(like it was) or put a gasket in between return and front of the liner. The SP1408 provides no gasket and sits right on liner. I am using "REAL-TUFF" for the threading's
I hope I described this well enough. I'm draining pool now to see if I can pull liner over the return (as it was originally)
Any help or suggestions are appreciated
Thanks
Richard
Thanks
Richard
