Holy smoke, that Pool Math app is spot on. It told me exactly how much chlorine to add to get to a target, and I'll be darned if it wasn't completely accurate!Shoot, I forgot that I had the app already. Thanks for the reminder!
Yep...from Pool School:OK, sounds like you approve of using muriatic acid
Just remember that PH measurements are not valid if FC is above 10ppm.My pH is off the chart now.
OK, thanks for that. I did not know that. My FC is currently between 6 and 7, whereas before drain I had to run it at a whopping 11.Just remember that PH measurements are not valid if FC is above 10ppm.
You can also get the MA in the paint department.. same stuff higher concentration. it maybe labeled as 20 baume, that same as 31% concentration. I don't think HD or WM has really started stocking pools chems yet for the season besides a few random bottles of CL...
That said, what is the best way to lower my pH without upsetting my other good levels? Way back at another house I lived in that had a pool, I just went to Leslie's and bought some muriatic acid. I looked at my local Home Depot and Walmart and they don't seem to carry anything for lowering pH. I have Leslie's in walking distance from, me, and according to Pool Math I only need 5-6 cups of their muriatic acid. Should I do that?
Turns out HD has it in the Gardening department. They said they cannot keep it near the chlorine because of explosion dangers. They have two types. 2 pack 14.5% for $10.88 and 2 pack 31.45% for $12.98. I got the 31.45% stuff. I used Pool Math's 29% formula, and used 5 oz shy of the recommendation, and wouldn't you know it, I went from 8.2 to 7.6 on the nose! That Pool Math is so nice. I have no idea if pH needs regular balancing or not, because I never had to add any before, so now I hope that the MA doesn't just sit and rot because I only used 1 quart out of 2 gallons. Or, maybe I want it to rot, because that would mean I never have to adjust it!You can also get the MA in the paint department.. same stuff higher concentration. it maybe labeled as 20 baume, that same as 31% concentration. I don't think HD or WM has really started stocking pools chems yet for the season besides a few random bottles of CL.
What other uses do you have for it? I couldn't believe the fumes coming out of the liquid, it looked like smoke. A light breeze blew in my direction, and some of it wafted into my face. I inhaled just a wee bit of those fumes, and it almost made me instantly pass out. That stuff is DANGEROUS at that concentration.Yeah I could swore I saw MA at the Folsom HD. MA doesn't go bad. it has a pretty long shelf life unlike CL. I have a SWG so I am using mine regularly. I keep some around for other tasks.
I didnt know that option was there. If I remember correctly, when I tapped the field, I saw 29 highlighted, 14.5 above it, and Dry Acid below it, so it looked like the options were listed in ascending order. I scrolled down, but didn't think to scroll backwards to look for 31.45 below 14.5. Great app, but I guess the list options aren't displayed inutitively enough. No offense to anyone who contributed to the app, since percentage is the first thing on each list option, as software developer myself, I would have ensured the list options were sorted in ascending (or descending) order by percentage.Regarding pool math, not sure why you used the 29% . There is a 31% option there as well.
