Replacement Relay
jaypool1
4
Raleigh NC
Welcome to TFP.
What is a WPC1 Controller?
What does the relay control?
That's a FiberStar controller, and your pump is connected to it right?
I can't remember if the WPC1 uses 24vdc as the control voltage, but I didn't think it did.
Can you post the data off the existing relay?
Thanks, this says 240VAC coil, existing one is 120VAC coil, will that work fine?
Also original is 2 pole, it switches both line and neutral, but this is single pole. Should i used 2 of them?
It has a 120 vac coil. That's what I thought it had.
Here's one version.
2PST 120vac Coil N.O. Relay
If you look around you can find several offered in different places. The important parameters are that it be a; Two Pole Single Throw, Normally Open Contacts, 120 VAC Coil, rated for 20 Amps or greater. And it wouldn't hurt for it to have a stated HP rating. That means that the contacts are designed for inductive loads.
Reactions: jonpcar
