I have had it now for a number of weeks, and so far so good! It has been flawless.
It fits perfectly just like the original. It has a built in DC cable, and you have to open the controller box to plug that in. But very simple. So a great value so far I would say.is the cell a direct bolt in or do you have to modify the piping connections?
Hello, I just had my AP1400 replaced, but now the controller inside the house says "FIRMWARE B12". Did thst happen to you, and if so, how did you fix it?It fits perfectly just like the original. It has a built in DC cable, and you have to open the controller box to plug that in. But very simple. So a great value so far I would say.
Still working great! I have been using the new cell all season, and running my pool filter around 10 hours a day, 9 hours of which are on low, the free chlorine level is around 5 ppm in the pool. I am running the cell at 80%. So it is running like a champ, and seemingly as good as the original. In some ways it is better, since the housing is translucent and you can actually see it generate the chlorine. Pretty cool actually.I am curious as well. Any updates?
Yeah, I saw some of that, but my experience has been perfect. Quick shipping from Australia, and my existing sensor works just fine. For the DC power cable you just open the controller box, unplug the old one, and plug in the new one. Nothing to it. The whole installation took me like 15 minutes, and it has worked perfectly from the start. Yes, I have a Jandy Aquapure 1400. If I get a few seasons out of this, it will be worth it. Otherwise I would need ultimately to replace the whole kit and caboodle, which might run $1,000 or more depending on what I get. This system has been running well since 2007, other than the usual salt cell and sensor shenanigans we all deal with.You have a Jandy 1400 right? Did the existing sensor work and you just had to rewire the power connector?
There's a ton of bad BBB if you search and the forum is against it: Platinum Edition Replacement Salt Cell for Jandy AquaPure 3-Port 1400 | 40,000 Gallon
But, you are having good results... I'm happy for you![]()
That was my thought. This is less than half the price. The original cell is so expensive, and my equipment is old, so I figured I would give this a flyer. These cells seem pretty basic in construction, so what the heck. So far so good.Why not take a shot given warranty and price when backed by Amex or equivalent. I’ll buy the same one and report my findings. Thanks!
Hey, glad to hear it!!THANKS @dndrich, I order mine a couple of months ago, and is doing great, running at 80% no issues, thanks again for your help.
