So I recently diagnosed that the control board of my Mastertemp needed to be replaced. It's not quite 3 yrs old and while the 'pool on' light was lit, none of the red ones were, it wouldn't kick on. The lcd screen was blank as well. So our installer brought over a new board. It's the r14 version and this one has the jumper that looks to enable or disable external control if you have something automated like screen logic (that's my assumption). We put the new board in and I've tried both positions of the jumper. In one, heater runs great but I have to control it from the heater, by setting the temp on the heater. Interesting point here, only the 'spa on' button will turn it on. The 'pool on' button doesn't work. Jumper in the other position disables the 'one buttons as expected but it isn't taking commands from my screen logic. This all worked great before I replaced the board. I've included some pictures. As you'll see, I've got the wires from the panel that screen logic uses. Confirmed they're seated properly. Does the board need to be configured in some other way?
Thanks in advance!
Thanks in advance!
