Replaced Hayward super pump shaft seal, now leaks with pump off
azuberi80
2
Maryland
My pump had started leaking when the pump is running from where the motor meets the pump housing .
I ordered a go kit and changed the shaft seal and diffuser/seal gaskets.
now when I put everything together it’s leaking when I fill up the strainer basket.
I have taken the bolts off several times to reseat them and they seem to tighten fine. I even put the original gaskets back in andit still leaks out just as fast aa my hose fills up the strainer.
I have ordered a new go kit in case the one I had contained a bad seal. Is there anything else I should be checking for?
JamesW
20,289
Probably something got assembled incorrectly.
Maybe some pictures of everything disassembled would show what's up.
