So it's that time again, my old Polaris 380 has once again stopped moving. Opened her up expecting the find the usual snapped drive belt. This year both belts have snapped, and the gears within the 'water drive' enclosure appear loose, several of the 'fins' on the main wheel are cracked/chipped, or flat out broken. This cleaner is 10+ years old now, and I'm leaning toward a fresh start... as I just don't have the time or patience to sit down and do a full rebuild.
Am I crazy to buy the 'older; 280 model to avoid replacing drive belts every other year? Is there anything I'm missing, or can I just order a Polaris 280 from amazon and plug her in.
Any reason to justify the premium on the Polaris 3900 model? It appears Polaris is running a $200 rebate, so the cost difference 280->3900 might be $100 or less.
Thoughts? Pros/Cons?
Thank You!!!
Thank You!!!
