Replace main drain valve
Show us pictures of what you need to remove.
I need to cut off 90 elbow to add a 90 sweep elbow to connect the new valve. The elbow I need to cut off is the main drain. Will water from the pool come out after I cut off the elbow. Pool water level is below the return.
