- Mar 5, 2017
- 603
- Plaster
- Hayward Aqua Rite (T-9)
Follow up question for all of you smart folks: are you aware of any cool "smart bulbs" to replace to existing halogen? I currently have a smart things hub which I am using for everything else. Would be great if there was a bulb out there that would let you change colors, dim levels, etc from the smart things app!
EDIT:
Also, wow this experience has me going down the rabbit hole! Now I am concerned that my pool is not properly bonded as it was built in 1954. I am having an electrician come out on Friday to check everything out.
It’s good to be informed Kev, and I apologize to the post as my last post here I didn’t read how far Along you’d got and my input was too holistic to be helpful.
I’ve revised my opinion on bulb swaps. If you need to swap a bulb for any reason, be that leaking fixture or just to put in a neato-fancy color change LED, I strongly advise pulling an entirely new fixture instead of s new bulb and gasket approach. The risk of (& high likelihood of) subsequent leaks is a major reason why most pool maintenance pros don’t swap bulbs anymore, and I’ve personally wasted hundreds instead of just pulling a new fixture.
There aren’t any current pool-rated LED bulbs that offer a WiFi smart connection (zigbee or other) approved for a pool. Best to have a rated bulb and have the switch take on that ‘smart’ work. You can conceivably use the suite of smart bulbs available, but I’d advise against them for pool duty, as the issues of functioning below water and concrete likely won’t get the functionality you’d hope for along with untested light dynamics.
As far as bonding, there are different levels of equipotential bonding. The NEC code keeps evolving to what needs to have bonding to now include the water itself, not just electrically conductive items—and having managed an older public pool (1970), they had to invest to meet each new code for insurance reasons. In my experience it wasn’t too expensive to meet the requirements for general safety. Generally, just like a house panel ground rod is attached to the steel rebar in the foundation, so is the initial bonding point for a pool. If your pool didn’t have that, it’s unlikely you’ll need that to begin a bonding from there, but if you ever resurface the pool might be an opportunity to address it as a firmer place to plant it. Concrete in general holds moisture best, compared to say dirt, so that’s usually why they recommend bringing it in from there and the attached metal rebar. Basically everything related to your pool that Might be electrically conductive must be daisy-chained bonded together using a bare copper wire. From what I can think, a retro kit may just have a bonding wire go through existing conduit to a light niche(s) and begin bond there and pull it back to your equipment pad.
In my experience with a much older pool there are more dangerous electrical items to inspect. Things like older electrical jbox locations (some right on swim deck coping), or improper connections that risk danger that a good electrician can review with you.
