Renovation- hearing conflicting information....
Caracbeara
Active member
Sep 7, 2019
39
Southeast, PA
CircuPool RJ-60 Plus
Hello! We’re planning on renovating our old Anthony pool from the 1970s (new finish, new deck, new tile) It’s never been replastered, so you can imagine what it looks like.
We’ve had three different companies come out and give conflicting advice.
pb1: Don’t get glass tiles. They break. Definitely get a concrete cantilever deck again. Plaster finish is fine. Quartz is an upgrade but will last longer if we REALLY want it. They will pressure test the lines.
Pb2: You should replace all of the plumbing. Glass tiles are great. Definitely get a concrete cantilever deck. We only install Pebbletec.
Pb3: Don’t do a cantilever deck. With the freezing of the northeast, it’s better to get coping separate from the deck. Glass tiles are great. We will pressure test the lines. We recommend Pebbletec but it’s really up to you. They will give us quotes for pebble, quartz and plaster.
Our heads are spinning and I’ve been searching threads all week. We’re looking for longevity but don’t want to break the bank.
My questions:
1. Is solid concrete cantilever deck the way to go in the northeast? Should we get a separate coping?
2. Is Pebblefina basically just like a quartz product? What are the pros of it? Pb3 prices it cheaper than some quartz.
3. Have anyone else chosen to replace all plumbing during a renovation? Is that overkill?
4. Right now our Polaris output jet is above the waterline. It makes for a somewhat nice pvc waterfall, but it pushes the water away from our skimmers as they’re all on the same wall. Pb 2 + 3 suggested putting it underwater. Will that help with our skimmer situation?
5. While glass tiles are likely out of budget, do they really break more often?
Thanks in advance!
Pic of pool attached.
sktn77a
2,012
Chapel Hill, NC
I guess it depends on what the mean by "replace the plumbing". If they are talking all of the underground plumbing, that's a major job. I wouldn't do it unless there is a problem with the pressure test. I know 60 year old pools with underground PVC pipes that don't show any signs of leaking
Reactions: Caracbeara
Caracbeara
Active member
Sep 7, 2019
39
Southeast, PA
They were talking about all of the plumbing. Probably why his quote was so high....
PoolGate
5,547
Damascus, MD
Jandy Aquapure 1400
This wasn't really conflicting advice you simply got 3 opinions. Go with whichever one you feel most comfortable with. I have heard the glass tiles do crack but if that's out of budget anyway then no biggie. I'd also want the pipes tested before replacing since that'll be a big expense.
Caracbeara
Active member
Sep 7, 2019
39
Southeast, PA
For an area with freezing temps-
would you all recommend brick coping over cantilevered concrete?
