I'd like to deep clean our sand filter following the instructional videos I found on here.
There is a warning about making sure the filter is isolated from the pool plumbing. I just want to be sure I understand... if I turn off the pump and turn the multiport to the close setting before removing the collar of the multiport, is that the proper procedure so water won't go through?
Thankfully, I have flexible tubing on mine so I don't need to cut any pipes.
