I have scale on my walls of a fresh water pool. It's really bad under the water line. Is there any remedy to remove this? I've tried scale remover and scrubbing with no luck. Thanks
You have a rare occurrence here. There may be a few (read as limited options).
First can you describe "really bad," or take a picture. Solution depends on the size and scale (size) of the scale.
Also, how are you testing your water? Can you give us a full set of test results? Me may be able to change your chemical parameters of your pool and help.
