Removing calcium from 6x6 travertine waterline pavers
tstex
1,788
Houston, TX
Hello to all,
I have intermittent buildup of calcium on my water-line Travertine pavers. Between a combination of a wide flathead screwdiver and 200+ grit sandpaper I can remove the calcium, but I cannot prevent a lot of the chips from falling into the pool. Will these chips be an issue and be reabsorbed into the water or stay whole and my robot can clean up the chips?
Thank you and pls let me know if you have any questions?
Regards, tstex
tstex
1,788
Houston, TX
Thanks Allen - with just replacing both tracks, all 10 sets of bearings and the impeller, it should be good to go...appreciate your help.
