Yes. The only time I get critters is when the autocover is not closed for whatever reason (torn or malfunctioning). I do get spiders and lizards which are small enough to squeeze through the small gap between the cover bar and the coping, but that's all.Do those of you with an auto cover that's on every night find these issues greatly mitigated/removed?
Why do you hate it? As long as you fish them out when you find them, and are maintaining TFP levels, you should be fine. I find mice, rabbits, frogs even turtles in my pool. Usually also in the skimmer basket. I dump them over the fence and never think about it again.
So the frog logs help with mice?
Where do you place them? Assuming one next to the skimmer and then one in the shallow end on the other side?
Anyone have any ideas on filling the skimmer lid hole but with something that would still allow it to be lifted off? Not sure what could even get through that hole, but I read one time that mice can squeeze through an opening the size of a dime.
Filling the skimmer hole won’t do anything. They get into the skimmer from falling into the open water and the skimmer does what it’s supposed to do by skimming the surface for stuff floating around.So the frog logs help with mice? Where do you place them? Assuming one next to the skimmer and then one in the shallow end on the other side?
I thought for sure we would have a ton of dead critters in our new pool, but most seem to hang out in the rain garden which is connected to all of our downspouts, decking and pool overflow. Not only do the plants look nice, I've found that this is a huge added benefit! Even if you don't need it for drainage purposes, it might be something to consider.Any chance to supply some water between the open area and the pool? Might keep some from coming to the pool.
