- Apr 17, 2022
- 15
- Plaster
- Liquid Chlorine
- Hayward Aqua Rite Pro (T-15)
have new 7000 gallon pool with Hayward tristar vs 950 pump and hayward c430 filter and hayward h400fd heater. pool equipment was turned on on july 4 2020 by contractor. At time he told me not to use release valve on filter that when cleaning basket on pump , pump motor would self prime. he stated valve will leak if you use it every time you empty basket . Pool man disagrees and uses valve when he empty pool motor basket. Yesterday he could not get valve to close and did not have way good way to fix I tuned pump motor off and opened and closed valve and then turned motor on. motor self primed and valve is currently not leaking. I live in Las Veas and have a friend at Leslies pool who found me a complete new vale incase this one leaks again They are not easy to get it being shipped to store on Monday , 155.00 dollars with gage and gaskets He only cleaned basket 3 times. Queston is contractor correct or poolman What to do ?
