Just purchased a home and inherited a spa/hot tub. Having issues even beginning to get the levels balanced. After adding baking soda several times, test strips are showing that the alkalinity has not risen at all.
Just had the water tested at my local spa dealer and here are the results, attached. Namely low ph, and high CYA and phosphates. Question: is this a situation to treat with phosphate remover and other chemicals? Or should I dump and refill the hot tub and start from scratch?
I don't see a major disadvantage to dump and refill, especially if it makes my job of balancing the chemicals easier in the long run. Again the history of this is unknown as we purchased a home with this hot tub, already full with water and unknown treatment history. So I wouldn't mind the baseline of knowing we have a fresh batch of water. But looking to anyone with more experience for recommendations. Thanks!
