refill how to open
Thank you; I appreciate your reply but just noticed it ...too late. I refilled (no water softener) due to high CC after removing winter cover.
Because of higher iron levels over the past few years, in city water, I put a sock over the end of the hose used to refill. It turned orange.
The forum helped. Water chemistry was pretty good: 7.7 PH, 250 Hard water, 125 Alkilinity and of course 0 FC & TC & stabilizer.
I added a pint of acid and following forum suggestions.... a hosiery sock filled with 2 lbs stabilizer (to begin with) in the skimmer basket, and a gallon of 10 % bleach with filter
running till I hit target readings.
I have had a pool for years but haven't had to drain and refill for years, so I appreciate your help!
