I understand the methods to reduce calcium hardness are generally to drain/refill with soft water or RO process. However, I was looking into possibility of precipitation to help pull it out of solution. This is discussed in other forums/articles but I can’t seem to find any info on this method in TFP forums. I really believe in the members here and it’s the first place I come to for questions/research on pool matters. I’m wondering what your thoughts are on this technique and it’s effectiveness/drawbacks as a way to reduce calcium hardness.
I actually discovered this effect accidentally last year when attempting to raise ph of my pool using soda ash after overdose of acid. It was my first pool. I observed the precipitate and then did some research into it. My well water is extremely hard.
Brief overview of method:
Raise ph of water using sodium bicarbonate/soda ash until dissolved calcium precipitates out of solution and then vacuum/filter calcium precipitate out. Raising ph to about 10 affects saturation index and lowers waters ability to hold dissolved calcium causing it to precipitate via ion exchange process.
Here’s a link to an article that discusses it.
aquamagazine.com
Please let me know thoughts....good and bad or otherwise.
Thanks
How to Fix 'Milky' Pool Water (Without Draining)
How to reduce the calcium hardness level in a pool without draining.
Thanks
