- Apr 11, 2019
- 40
- Plaster
- Hayward Aqua Rite (T-9)
Hello!
when should I reduce the % of the swcg and when should I reduce the run time?
10k gallon pool, Hayward T9 at 30%.
My pump settings are roughly:
800rpm for 4 hours (~20gpm, so minimum for the swcg to work)
2500rpm for 2 hours to skim
800rpm for 6 hours
With this, I’m finding I have around 9ppm of chlorine pretty consistency. stabilizer around 50, so my target is around 5, and I feel comfortable around 7ppm.
should I drop to 20-25% or knock an hour off the runtime? Is there a minimum % for the chlorinator I should aim for? Given that it’s a finite runtime, seems like the ideal would be set the Hayward to minimum and run the pump 24 hours a day?
800rpm for 6 hours
