Hi, TFP community!
I have a couple of pretty simple questions, but let me start with the results of my most recent test (using a Taylor fas-dpd kit:
Alcibiades
—-Edit: I don’t see my signature, so here it is—
30K gal A&S in-ground plaster pool; JP PlusHP 2 HP pump; JP DEV 60 sq ft cartridge filter; FusionSoft 1400 SWG (mineral cartridge removed); Polaris 3900 Sport w/ PB4-60 booster pump; Heatwave AquaCal; JP 2444 valve actuator; iAqualink . . . and a "Wall Whale" for regular scrubbing!
- FC 2.8
- CC 0.4 (usually 0 or 0.1)
- PH 7.8 (tends to rise over time)
- TA 70 (stays constant)
- CH 375
- CYA 70
- Salt 4100 (very strange—jumped from 3300 with no addition of salt)
- Since the pump was fixed three days ago, the salt level readings from my SWG have been strangely high—jumping from 3300-3500 before the pump failure to 4100 over the past few days. Any idea what may have caused that and how I should deal with it?
- My SWG often doesn’t generate quite enough chlorine to hit the goals I see in Pool Math for salt pools. I run the cell at 70% for 12 hours a day. Is it reasonable in the sunny Virginia summer to up the cell to a higher percentage, or will I risk burning it out?
- My PH levels tend to rise over time and settle at the high end of the recommended values (around 7.8). I’ve read in these forums that this can be common with SWGs. Any tips for minimizing the up-creep (and should I be struggling to keep the PH at a lower value if it likes to live around 7.8)?
Alcibiades
