My spa LED light has been pulled off the wall by my pool robot. The wall screws have pulled out of the plastic frame on the pool wall.
Is it safe to empty my spawater into the pool or is there a risk of the walls collapsing, eg do I need to empty all water? My pool depth is about 1.5 on the opposing side.
Do I need to support the walls with timber across the spa?
The pool is approx 30 years old, what’s the best way to fix this, the plastic pool light wall frame has deteriorated and not sure what I need to reattach. Do I pull wall anchors in the concrete or is that a bad idea, or do I use some other kind of mount?
